M-audio Soundcard
Discussion in 'Computer Components' started by img, Sep 12, 2004.
  1. img
    Jan 22, 2004
    575
    +17
    Just got revolution 5.1 sound card and cant seem to get few things to work. I can get movies to play through the link to my amp with the digital co-ax connection but is there a way to play mp3`s or music through it.
    Also cant get my mic to work at all been looking for ages and cant get it to work.
  2. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,718
    71
    Land of the Living, Essex
    +34
    Switch the speaker setup to digital in maudio control panel mate
  3. img
    Jan 22, 2004
    575
    +17
    i had switched to audio but still didnt work, decided to put xp on and now the digital works but still got no mic.
  4. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    Have you turned on monitoring, thats what I needed to do to get the mic to work, make sure you turn down the level before you do or you'll blow your speakers.
    owain
