M-audio revo - surround sound for games?
Discussion in 'Computer Components' started by PFM, Jan 4, 2004.
  1. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Im considering the above M-audio sound card, can any of you folks out there tell me if this card will allow me to output surround sound for games via a Tag AVR32 processor & amps, or will I be stuck in stereo mode?
    My Projector is in a different room to the PC, so I would like to occasionally take the PC through for HTPC use and/or big screen gaming or if it works for surround gaming knocking up cable runs for permanent connection.
    Can it be done?
  2. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    I've used mine no problems with counter strike and Soldier of Fortune II. I don't play many games though :) You have to change a setting in the control panel to set the card to gaming mode.
  3. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Thanks for the reply nutcase,
    Did you achieve the surround sound for PC games through your coaxial output into an AV amp/processor?
  4. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    +3
    No, you have to use analogue. Unless you have an onboard encoder that can put it into something your amp can decode. I think it's the Nvidea sound chipset that has onboard dolby digital encoding. Then you could do it using analogue.
  5. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Hmm,
    Are there any cards that can output a Dolby digital or DTS signal (digitally), 4.0 5.1, etc etc?
  6. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    +3
    I havn't heard of any, but I'm well out of touch on what's current. About a year since I last looked. All I have heard of is motherboards, which is a shame really, as it is quite a major upgrade just to achieve something that could possibly be put on a soundcard. The only reason I can think of why they can't is bandwidth issues. But you can stream pre-encoded DD accross an IDE bus and then to PCI with no problems, so I doubt there's a problem.
  7. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    The only soundcards which will encode to Dolby Digital are the ones built into some NForce based motherboards. To get surround from your Revo you would have to take the 5.1 analogue outputs and connect them to the bypass inputs on the Tag. The Revo doesn't do as much (any?) hardware acceleration of 3D sound compared to something like a Soundblaster Live so can slow down older computers, a modern P4 or Athlon shouldn't have a noticable problem though.
  8. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
    Can you do this with an RME if you have the add-on board for 6 channel out?
  9. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Thank Crispy,
    Whats A RME?
