M-Audio BX5A Deluxe Monitors or audioengine A5 (Xonar D2X)
Discussion in 'Computer Components' started by Sleepy, Feb 11, 2009.
  1. Sleepy
    Sleepy
    Sep 29, 2007
    845
    28
    +43
  2. Repton
    Repton
    Mar 1, 2003
    1,211
    Wirral
    +135
    I believe the BX5a Deluxes are more powerful, each monitor is bi-amped (70W RMS each), requires it's own power supply and are proper studio monitors at a budget price. For me that is better value.
    Sound wise, can't compare with the Audioengine A5 as I have not heard them, they are extremely revealing and has a sweet treble with taught bass.
    More here:
    YouTube - M-Audio BX5a Deluxe Active Speakers
    also a dedicated forum here:
    Speakers, Headphones & Earphones - The Official M-Audio User Forums
    Downside?
    You hear quite a bit of reliability issues. Mine is superb at the moment.
    all the best.
    thought you only have £100 to spend?:D
  3. thelawns
    thelawns
    Mar 7, 2005
    1,665
    +146
    I still can't decide if I want to buy the M-Audio BX5A Deluxe's at the moment. That review has helped no end though, I enjoyed watching that so thanks for the post! :smashin:
    Someone else mentioned the KRK RP5's as the best competitor to them, both price and performance wise. Anyone tried these?? I am a bit of a sucker for the M-Audio range though! :rolleyes:
  4. Repton
    Repton
    Mar 1, 2003
    1,211
    Wirral
    +135
    You should check out their own manufacturer's forums to see when has the best reliability performance and general customer satisfaction, hope that will sway your decision! By the way, I still love my M-As!:D
  5. norsk
    norsk
    :)Hello Guys..
    I have just being told about this thread which is on the subject...i am posting about elsewhere on the forum....
    i just wondered if any of you had update information on the active speakers in the thread? if so i would love to hear as these speakers are the ones that keep being mentioned to me...
    but i need a bit more information to make my final decision?:confused:I really am no expert but know approximately what i am looking for...i hope anyway
    just to recap: i have dell studio 17 as source..playing 95% Mp3 files..also sandisk sansa fuse 8gb ...i am looking for a good compact set up for my room...will not be connected to Hi-Fi...
    so any advice on the different areas of the set up very much appreciated..
    do i require a DAC? this confuses me..and do i require a power source for the M-audio Audioengine and the others you were discussing/
    all the best Steve:thumbsup:
