M-Audio 2496 Setup
Discussion in 'Desktop & Laptop Computers Forum' started by sneaky, Sep 1, 2004.
  1. sneaky
    sneaky
    Dec 14, 2003
    348
    16
    North East
    Hi All,
    Ive just setup the 2496 - everything stable.
    I now want to get the best out of the card - is there a best way to set it up. Are there any do's and dont's for setting up the card for both digital and analogue.
    Also what is the best way to go in regards to playing ripped cd's with this card.
  2. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Sneaky:
    I've only had my 2496 card for a few weeks, sounds great with TT & DVD's.
    Finally worked out how to get ASIO working and avoid the k-mixer in windows.
    Have a look at this link for more info on Winamp & ASIO......
    http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=409372&highlight=winamp+asio
    Still not sure if i've got the ASIO driver setup correctly in Winamp v5.1
    As for sound quality, i still love the sound of my Marantz 67mk II CD player over the HTPC.
