m-audio 2496 no sound via optical when playing dd plus
Discussion in 'Computer Components' started by philthyanimal, Sep 21, 2007.
  1. philthyanimal
    philthyanimal
    i only can get sound out of the 2 analogue outs when playing batman begins. using power dvd ultra
  2. dogbert
    dogbert
    Feb 6, 2005
    207
    28
    +24
  3. philthyanimal
    philthyanimal
    shouldn't it down mix it to dd?
  4. dogbert
    dogbert
    Feb 6, 2005
    207
    28
    +24
    uhm.. it's not downmixing in the sense that a the sample rate / width is adjusted, it's transcoding (decoding to PCM and re-encoding to regular AC3). the wikipedia article says that transcoding isn't mandatory for decoders, but I guess it's just a matter of time before a software player implements that.
    the transcoding isn't optimal with regard to audio quality, but since the ddplus receivers are in their first or second generation, it would be foolish to buy one now.
