rjcedar
That's right, after the update you will get the choice "speakers + 1 BW-2 sub".
THANK YOU!
The software update changed SW version from 1.36a/DSP version 2.06a, to SW version 1.4a, DSP stayed the same. And that new choice for spekars and 1 bw-2 sub came up.
i did Advanced Settings/speaker setup/ chose 1 sub and then ”speakers with BW-2 sub”
Ran Speaker setup guide and chose sub connected to ANALOG OUT. On the sub, now line in is to bypass (bypass sub controls) and input switch to bypass.
Sound confirmation came from all 3 speakers, now the sub does respond! But the test confirmation response sound from the sub is much diminished from the test sound coming from the speakers, I about that.....
Ran RP to 98%
Now in MENU, for RP, I can set RP menu between focus or global. Choice was stuck on bypass before, no other choice.
Played system tester music, and found MUCH more base is coming from the main speakers that the sub. Sub sound level out is VERY soft.
Tried changing voicing, from neutral to action movie , base 1 and base 2. Still, so much more base is coming from the main speakers than the sub.
Should I be going into ADVANCED SETTINGS and be applying high pass to speakers and low pass to sub, to get a better balance between what is coming out of the sub? I thought with the preset ”speakers with BW-2 sub”, that the right crossover frequency assignment would be made, and I would not have to do any more tweaking.
What am i missing? What else to check?
Thank you.
