Quantcast
Lyngdorf discussion
scoc
you could always get one of these if you want to use SPdif.
Thx for the input. I’m thinking adding the Metrum Ambre streamer with AES output instead of my music server’s usb output.
orange55
For the last 6 months I have been using the USB input on my LA3400 where-as the 6-7 years before I used AES or SPDIF. I cannot really describe it very well and my memory might not be that accurate but I found the SPDIF and AES inputs considerable better sounding than USB. Although usb sounds and good the sound can be a bit edgy and hard sounding and not as smooth as before with spdif and AES. The lan input on the LA 3400 is not better than usb I've tried that as well. I'm thinking of adding a separate streamer with AES output to avoid USB. I know there are various ways to improve usb with reclockers and other power supplies and even a different clock etc. But that's all adding various boxes just to try to improve the usb output where-as I think others like AES are better suited for audio. It's not that usb sounds bad on the LA combined with my Innuos streamer but I recall it sounding better before with my Nad M50 with AES output (I cannot compare this now anymore since I sold the NAD).
I use Ethernet for my MP-50 for music and that works really well.
I use Chord Company Ethernet and that had a big impact on the quality and timing of the music. I also have a audiophile switch which improved everything including Netflix picture quality.
scoc
Ok, but the MP50 has no decent media player built-in so that’s not really an option. The builtin MP50 player is terrible from a usability point of view. The LA3400 at least has Roon.
donttrustgoats
The MP-50 has the exact same media player as the 3400, they're just waiting on Roon certification.
scoc
No that does not seem to be the case. The MP50 is not a Roon endpoint and I believe LA said so as well and they’ll not provide a firmware update to make the MP50 Roon Ready.
donttrustgoats
Nah, I'm gonna go with you being wrong :D
"Hi
We are just waiting for Roon’s certification – as the player is the same as the certified TDAI-3400, it is only a matter of time.
Best regards
Flemming Smith
Lyngdorf Audio"
arisholm
"Hi
Best regards
Flemming Smith
Lyngdorf Audio"
Not sure if you remember but a while back, due to a configuration management mistake, the MP-50 suddenly had Roon support (I think it was version 3.0.7). It was a bit buggy but sounded great when it worked. But then they issued a "fix" that took it away, I suppose since it was not certified yet. So it will come, no worries ;-)
indus
I'm confused by you guys using this Metrum Ambre. If you use the digital out into your Lyngdorf then you've paid £1000 for the high quality dac in the MA and then bypassed it.
Doesn't it make more sense to buy some kind of streaming transport?
scoc
No, the Metrum Ambre IS just a transport and it has no dac inside just digital out.
arisholm
I think that is exactly what the MA is - a Roon end point with AES, Coax, AES, Optical and I2S outputs, so a Roon "streaming transport".
Whether such a streamer is needed given that the 3400 is already Roon Ready and the MP-50 soon will be, is another question. Personally I hope I can sell my microRendu streamer as soon as the MP-50 supports Roon, but it will be interesting to A/B the two. I noticed that dCS recently re-implemented their Roon/RaaT support so I guess there must be some room for improvements in the implementation details even if Roon supplies a SDK...
More info for geeks: Roon Knowledge Base - RAAT
indus
larkone
and
What the ASA had to say about Chord Ethernet cables
The Chord Company Ltd
kees1000
Metrum Ambre is Roon only. But Roon is not the only Holy Audio Grail..... What I miss is the LMS/Squeezelite solution. Not only in the Ambre, but also in the TDAI 3400/MP50. Is is small, simple, in every NAS available and sounds really good.
orange55
and
I didn’t buy on their marketing material. As with all my music purchases I buy with my hears. That includes the music and the hardware.
It’s all a personal thing, like car ownership, where we choose to buy our houses ...
larkone
So what you are saying is that a Chord Ethernet cable is intelligent enough to unpack TCP/IP packets, find the exact bit to change to improve the sound, recalculate the check bits and then repack the packet in real time - wow seriously intelligent copper or is it magic?
orange55
No I am saying I like Disclosure but not Michael Jackson!
orange55
Just noticed your signature.
“Minds are like parachutes - they function better when they are open.”
That doesn’t align with your comments.
larkone
I think it does - it would need a seriously closed mind to believe a piece of copper has that much intelligence.
Rock Danger
If you subscribe to the ethernet thing then you have to by default do the same with HDMI cables - don't see a lot of that happening here tho.
It all goes back again to people saying Pc's are noisy.. they're not anymore. Some routers are horrendous and like cable/sat boxes can dump sh*t all over your connected system, however hardware does 99.999% of the heavy lifting to fix things, not the cables when they're half decently made.
The open mind argument is kinda like saying 'well it was ghosts and if you don't believe in ghosts then your frequency response will suffer'
orange55
OMG ... I need to move to a haunted house now?
:rotfl::facepalm:
Rock Danger
:rotfl::facepalm:
Or move in with Russ Andrews.... christ, imagine being stuck beside him on a long haul flight.
indus
orange55
Trending threads
Latest News
Disney CEO Bob Iger steps down
  • By Andy Bassett
  • Published
Quantum Dot development could mean cheaper displays
  • By Andy Bassett
  • Published
Netflix launches daily top ten rankings
  • By Andy Bassett
  • Published
OLED TV sales exceed one million in Q4 2019
  • By Andy Bassett
  • Published
Bowers & Wilkins CEO leaves amid restructuring
  • By Andy Bassett
  • Published
