Rob Sinden
I think Lyngdorf stereo amplifiers now warrant a thread of their own, so here it is.
Lyngdorf amplifiers are very different from most traditional amplifier, so its worth pointing out a few of the key differences they claim about their products:-
Room Perfect – Put a very good CD, amp and speakers in a room and you will typically get 15db variation from what the speaker designer intended. This means that some sounds will be heard four time louder than another. Anyone who has moved a hifi from one room to another will know how much the room affects the sound of your system.
RoomPerfect can be set up by anyone and requires no specials training, laptop or internet connection. It is the only room correction systems designed for very high-fidelity music systems and that preserves the sound of your speakers rather than changing them to fit the intended response of the EQ system.
No amount of room design and treatment or accessories and tweaking can accurately correct the errors created by the listening room in the same way digital room correction can.
Digital Design – Lyngdorf amplifiers are essentially very powerful DACs. Connect them digitally to your sources and the signal path between your recordings and you speakers will be kept in the digital domain much longer. The end result is cleaner, clearer music.
If you have large floor standing speakers, you may think multiple amplifiers are required. Traditional analogue amplifiers are very inefficient, so most of the power they consume is turned into heat and not sound. This is why, the chassis for powerful amplifiers are so large and expensive.
Lyngdorf digital amplifiers are far more efficient so the TDAi3400 amplifier for example, is in a compact chassis that delivers 2 x 400w and is capable of driving the grandest of speakers.
Subwoofer Integration -We believe a high-end music system should be able to reproduce all the sounds in your recordings down to 20Hz. Loudspeakers that do this are very big and very expensive. A high-performance subwoofer has the potential to reproduce the lowest frequencies in your music, however typically their addition to a good hifi can make the sound a little ponderous while timing is also affected.
RoomPerfect is unique in measuring and correcting the sound of your speakers and subwoofers together. Once RoomPerfect has been run you will achieve a seamless splice between your speakers and sub and a far more even in room response.
