LX81 Best audio setup for PS3?
Discussion in 'AV Receivers & Amplifiers' started by Showoff, Feb 3, 2009.
  1. Showoff
    Showoff
    Dec 15, 2008
    3,501
    +3,239
    I had the same question for Sky HD, but after a bit of searching on here it appears to be HDMI for the picture and Digital optical of the sound, but what about the PS3?
    I've read a bit about using a PCM-HDMI input on an amp for the best sound, is this true and does the LX81 support this? Assuming not as can't find anything in the manual what is the best cables and settings?
    Thanks.
  2. Showoff
    Showoff
    Dec 15, 2008
    3,501
    +3,239
    Just found that this amp does playback audio in PCM, so just the original question about what is best set up for audio, HDMI only in 5.1 PCM (which I suspect is the case) or HDMI (for picture) & Optical (for audio) as appears to be the best case for Sky HD?
    Thanks.
