Question Lx5090 Freeview not working fully
Discussion in 'Plasma TVs Forum' started by TVGirl, Jul 26, 2018.
  1. TVGirl
    TVGirl
    Oct 28, 2007
    27
    Sussex
    My Freeview in the living room stopped working -just a blank screen & no sound- so I thought “Aha, it needs simple retuning for new channel and channel changes”, which has happened in the past. I don’t watch Freeview much so I’m not sure when it stopped working. The TV (at the bottom of screen) says “Plasma Display This Channel is not in service”
    I did the retune and I stilll have no picture or sound on any Freeview channels. However I do have the Freeview epg!
    I looked at our 2nd Pioneer, a 428xd and it’s the same issue! The 2 TVs have separate feeds from the loft.
    Our Samsung in the kitchen has Freeview working normally and no retune needed. We use a magic eye system to feed sky & Freeview to the Samsung.
    Please could you give me some help about what I need to do to solve this issue? Is it an aerial issue? We are in Brighton, Patcham transmitter, if that is relevant. Or is it a tuner issue on the Pioneers?
    Many thanks for your advice.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,998
    Lanarkshire
    +2,617
    Check whatever the two feeds go to in the loft, probably an aerial distribution amp.
    Try one of your non-working TV's on the kitchen aerial outlet.
  3. TVGirl
    TVGirl
    Oct 28, 2007
    27
    Sussex
    Thanks, yes there is a distributor in the loft. I’ll get up there and check it for good connections as soon as it cools down enough to go up there!
