LX-SC71 amp - what stand?
Discussion in 'AV Receivers & Amplifiers' started by lunarwolf, Feb 12, 2009.
  1. lunarwolf
    lunarwolf
    Jan 11, 2009
    518
    +46
    just bought one and didnt think it would be that huge :lesson:
    any recommendations for a stand? it will also need to support my plasma 5090, ps3 and xbox
    PS i have seen a Alphason | Iconn Series - Model: ST300 120-B - open stand but am worried that with only 2cm clearance on bottom shelf it might be a close call for the airflow
    your thoughts?
    cheers
    Amp Dimensions (W x H x D) 420 x 200 x 459,5 mm @18.5kg / TV 50" weight 33kg
  2. cmcdonnell
    cmcdonnell
    Jul 28, 2005
    91
    +5
    I have an Soundstyle ST310 with a Pioneer 508XD on top, with an B&W LCR6 (a big centre speaker) on the middle shelf and my SC-LX71 on one side of the bottom shelf and my BDP-LC08 and SKY HD box on the other. Plenty of room all round, it's a really nice rack that I would thoroughly recommend.
  3. Alistair
    Alistair
    Dec 1, 2008
    236
    28
    Gloucestershire
    +39
    I have one of these stands (SONOROUS) and the '81 sits nicely on the left side of the bottom shelf. Bid of a squeeze getting it in there since the amp is so deep but is good. :)
  4. Danepack
    Danepack
    Nov 23, 2007
    280
    28
    London
    +33
  5. DavieW
    DavieW
    Feb 1, 2008
    241
    +23
    Try the Alphason AD3/105, my LX70 fits fine. Here's a tip, when I was looking for a stand, I made paper templates the exact size of the 'footprint' of my kit. It was easy then to place them on different stands to check it they will fit. You'll also need a tape measure for the height.
    Good luck,
    Dave
  6. lunarwolf
    lunarwolf
    Jan 11, 2009
    518
    +46
    thx for all the tips, in the end i decided on the Soundstyle ST310, had the room I needed and looks solid - now awaiting delivery
  7. Klar
    Klar
    Nov 21, 2008
    2
    London
    I am pretty much settled on the SC71 but would appreciate any feedback on space/cooling requirements. I would only have 20mm clearance above the unit when installed, although there is more space at the sides and the back would be open. How hot does the unit run and has anyone had problems with overheating?
    Thanks in advance
    Klar
  8. cmcdonnell
    cmcdonnell
    Jul 28, 2005
    91
    +5
    My LX71 runs pretty cool even at -10 to -15db. I have a good 5 cm clearence using my ST310 stand but I feel it would be fine with half that.
