LX-5090 & Sky+HD Picture Settings
NealBennett
What is the general opinion on the best Sky+HD resolution setting with the 5090 on both SD and HD broadcasts?
I used to have the resolution set manually on the box as 1080i.
I have read a few posts that say that changing this to Automatic is better? If I select this setting, the TV sets a resolution on SD broadcasts as 575p.
This produces a slightly larger picture in terms of a lower resolution, (larger sky menu being displayed for example) compared to manually setting to 1080i on the Sky box. Gives the feeling I am seeing more picture due to the higher resolution.
What are peoples recommendations on this?
Neal.
Berties
If things are "bigger" than you're zooming in which means you're seeing less plus resolution is lower. Zoom into a jpeg picture and that's the same principle.
I'd use full or dot by dot mode.
NealBennett
Hi Berties
I have the 1080i mode set to full with dot by dot enabled.
When the TV switches over to 575p (when Sky box is set to auto) it is set to Full. If the Sky box is set manually to 1080i the screen displays 1080i all the time.
That was the reason for my question really, do most people allow the Sky box to feed the TV a constant 1080i signal, or allow the TV to do the work?
Neal.
Berties
I'd probably set the sky box to 1080i, otherwise if you set standard def out, sky box is downscaling HD to SD, then the TV is scaling that back up to 1920x1080.
Since it's interlaced you've probably got some de-interlacing options somewhere in the TV picture settings, think called something I/P?
bladedripper
I have the sky box at 1080i all the time,i find itsthe best allrounder.:smashin:
