LV shower halogen switching from shower switch?
Discussion in 'Smart Home, Climate Control & Security Forum' started by brains, Mar 1, 2005.
  1. brains
    brains
    I will be buying an Aqualisa Axis Digital Pumped shower with an Aqualisa Dual (parallel) Switch to go outside the shower.
    I want to have the shower light come on only when the shower is switched on (not only when the pump is switched on for boost).
    Presumably the switch circuit is a safe low voltage. Could I wire a relay into that circuit which is LV switched but 240V switching?
    What would be a suitable relay?
