Lutron Grafik Eye
Discussion in 'Home Cinema Buying & Building' started by David Ravenhill, Feb 10, 2009.
  1. David Ravenhill
    David Ravenhill
    Mar 26, 2007
    12
    Hi Guys,
    Could someone please tell me if a Lutron Grafik Eye 3106 can be used with low voltage downlights.
    Cheers.
  2. dalethecaptain
    dalethecaptain
    Jun 26, 2008
    682
    28
    Chesterfield
    +42
    You can use them with low voltage down lights, however you need to make sure the transformer is compatible, I pretty sure they have to be 'leading edge' type electronic transformers. There are a few PDF's on Lutron website that explain the types of loads that can be driven and the extra interfaces that are required, I will try and search out the relevant one as the site is not very users friendly.
  3. habrown
    habrown
    Apr 29, 2008
    40
    +4
    Yes, it is a Leading Edge dimmer, so the relevant Transformer to this is required. This is a good thing though, as it is easy to buy the cheap trailing edge transformers which are a pile of imported poo, and will force you to buy something half decent!
