Lutron Grafik and fluorescent tube lights
Discussion in 'Home Cinema Buying & Building' started by hifiphones, Jan 9, 2012.
  1. hifiphones
    hifiphones
    Feb 21, 2010
    203
    +17
    I have tried both with Lutron Grafik Eye and Lutron Grafik Integrale. Both have the same issue.
    I got a fluorescent tube (1) with built in electronic ballasts. The problem is, that when this fluorescent light is set to "0" (off) in a zone, the light flickers slightly.
    When the light is turned on, there is no flicker, also when the Lutron is turned off via "ALL OFF" button there is no flicker.
    I have set the light as "NON DIM, FIRST ON FIRST OFF"
    Any ideas? Might the reason be that the load is too low? (1light), or the light is not suitable?
  2. Matt2
    Matt2
    Mar 27, 2010
    29
    3
    Generally, fluorescent tubes are not dimmable. Either on or off no in between, so this is probably what is going on,
  3. hifiphones
    hifiphones
    Feb 21, 2010
    203
    +17
    The light zone is set to "NO DIM FIRST ON FIRST OFF"
    EDIT: Problem solved, there was an issue with current leakage on the specified zone output. I increased the load on the zone and no more flicker!
