Question Lutron Fault Help
Discussion in 'Smart Home, Climate Control & Security Forum' started by bardel, Apr 14, 2016.
Tags:
  1. bardel
    bardel
    Jan 23, 2004
    1,006
    2
    87
    Essex
    +256
    I've recently moved into a house that has Luton lighting and a SystemLine audio / lighting control system.
    In the last day our landing lighting is no longer working when we press the buttons on the panels. I've looked in 1 of the 2 cupboards where the Lutron stuff is and I can see that one of the panels appears not to be illuminated. I'm putting 2 and 2 together and presuming that this the one that relates to the landing lighting!
    So question is, is there a fuse or something simple that I can check or reset to get this up and running again, or is it more likely something has gone poof and needs an engineer?
    Picture attached of the Lutron panels. The top left panel appears to be off?
    Barry
