Luninance and Chrominance - is this another flavour of component?
Discussion in 'Plasma TVs Forum' started by alanfcross, Feb 27, 2005.
  1. alanfcross
    alanfcross
    Looking at my SCART connections and cables, I see that SCART caters for RGB, and for composite, and also for 'Luminance' and 'Chrominance' (one pin for each).
    I thought Component was a three-wire system - luminance and two colour difference channels. So what is this? Is it two difference channels PAL-coded or something, but with Luminance kept separate? Is this something we should avoid?
    A related question ... can SCART cater for full component (YUV style)? I know it's only a piece of wire, so the question is really do kit manufacturers use SCART for this, or is YUV always on BNCs/RCAs?
    Yours, confused!
  2. mannyo
    mannyo
    Feb 6, 2005
    758
    28
    Blandford Forum
    +77
    I think thats S-Video not component.
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    There are 1 or 2 sources that do component on scart, most notably the Netgem freeview box. Some RPTV's can accept the signal on scart, I came across a Sony one that did. Otherwise, if you have one of these few sources, you get a scart-RGB on 3 or 4 phonos, and connect the appropriate ones. The YUV is on the actual RGB pins.
  4. alanfcross
    alanfcross
    Thanks, guys. Never used S-Video, so never thought of it!
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    S-video is a component signal Y/C but usually it is YUV/YPbPr that is reffered to as Component (RGsB, RGBS, and RGBHV are also flavours of component video) YUV/YPbPr is the norm and is based on the colous space which is different for RGB........signals
