Lumagen Vision pass through
Discussion in 'Projectors, Screens & Video Processors' started by sticker, Jan 12, 2004.
  1. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Does anyone use or understand how the pass through (input 4) on the Lumagen Vision work?
    I'm trying to us a DC via this input but I'm getting no outout. Do I need to change some menu settings in the Vision or have I got hold of the wrong end of the stick of the purpose of the pass through port?
    Regards
    John
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    I can't comment on the Lumagen but I have my PC hooked up to my iScan Ultra via the pass-through port and then have my iScan Ultra outputting RGB to my panny plasma via a 15pin VGA-VGA lead.
    I have not tried but I don't think the same would work if I had the iScan set to output YUV or if I were using a VGA - RCA lead instead.
    Not sure if that helps any.
    Cheers, Lee
  3. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Hi Lee,
    Thanks for the reply. It seems that mine is the same set-up as yours so it must be a setting somewhere in the Lumagen
    Regards
    John
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    I have a gamecube set up on my vision and I get a rolling mess but that is all.
    I was going to order a cable to upgrade the firmware and see if that sorted it out.
  5. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Gizlaroc, how is the firmware upgrade done?
    Wonder if Gordon is around as he may know the answer to this.
    John
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Look on their site, it tells you how to make a cable and the firmmware is on there. :)
  7. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Cheers mate
  8. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Gordon F, if you're out there, do you know the answer to these problems?
    Regards
    John
  9. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Just back from CES.
    Input 4 of Vision shold just pass through the info sent to it. No transcoding is done. So if you are outputting RGBHV then feeding component rhough pass though is no use unless you also tell your display to change to component in when you go to pass through mode on Vission.
    The Pro's need to have their inputs set up for pass through or not.
    You can build your own parallel leads from instructiojns on site or you can buy serial leads from me for £15. Programming is simple. If you are having issues getting pass through to work email me direct with where you bought it and when and I'll see if I cna help
    Gordon
  10. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Gordon,
    will give you a bell about buying a programming cable.
    I bought mine used from someone upgrading to the vision Pro, so I have just lived with the pass thru not working, passing rgb/h/v btw.
    But I may as well upgrade the firmware and see if that sorts it out, as it would be nice to have d-vhs, gamecube and xbox going into a transcoder then passed through.
    are you doing any component switchers Gordon, like the Audio Authority one ??
    cheers
    Guy
  11. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  12. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Ok will do cheers
    I will speak to you later about the cable.
    thanks
    Guy
