Lumagen software update
Discussion in 'Projectors, Screens & Video Processors' started by Thunder, Jan 11, 2005.
  1. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Hi guys, does anybody know if updating the software on my vision HDP removes the current saved settings or are they retained :confused: :)
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    The settings are retained unless the blurb for the update says otherwise...some of the more major updates did wipe clean everything but the later ones have been okay.
    Cheers, Lee
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I saw a comment from Jim or Pat on AVS about this, their answer was that was necessary in one of the earlier beta releases but they don't see any reason why they would have to do that again with the updates they are working on and have planned.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    I can confirm that in the past 10 or so updates that I have done since getting my HDP, none of them have cause the loss of my settings. Saying that though, I have downloaded but not installed the latest software release, so fingers crossed :devil:
    Mark.
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    There is now an application on Lumagens website that allows you to store your config in your pc. You can then send it to others to try or to Lumagen if de-bugging is required. This should allow folk with similar systems to easily set up there units and share timing ideas etc.
    Only one beta update removed settings. All current and proposed future updates shoudl save config before re-writing memory.
    Gordon
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Back from CES then Gordon? :)
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  8. Chris5
    Chris5
    Mar 21, 2004
    1,288
    63
    Herts., uk
    +179
    Welcome home, Gordon
    P.S. Do you have the knowledge (codes) for doing an ISF calibration on an Optima RD50?
  9. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Ah, the lifestyle some folks lead. :laugh:
    Hope you had a good time, but I'm glad you're back because Joe may be needing your services soon. ;)
