Lumagen Radiance / Radiance 20XX Firmware Updates
Discussion in 'Projectors, Screens & Video Processors' started by ConnecTEDDD, Jan 29, 2014.
  1. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 011714 Firmware Update
    Release Notes
    Adds a clean transition for aspect changes.
    Fixes stereo/Coax/Tos audio input to HDMI audio output.
    Fixes loss of audio for some audio format changes on input.
    (Update time ~3 minutes @57k)
    Download Link
  2. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 011914 Firmware Update
    Release Notes
    Fixed up an issue (in 1204-0117 firmware) causing loss of video for some DVI displays.
    Download Link
  3. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 011814 Firmware Update
    Release Notes
    Fixes occasional loss of audio for some audio format changes on input.
    Download Link
  4. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 012014 Firmware Update
    Release Notes
    Fixed an issue where if using only one output the input colorspace could sometimes be incorrect on power-up or when changing colorspace settings on the source resulting in pink/green video until changing inputs or turning off/on (bug in 1201-0119 firmware).
    Download Link
  5. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 012814 Firmware Update
    Release Notes
    Fix for loss of audio on some sources (seen on DirectTV box) when powering up or changing channels.
    Download Link
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,112
    New Firmware for 20XX models to sort out a small bug i came across yesterday...pretty amazing service again by Patrick. I reported the bug mid afternoon UK time and by late evening it had been recreated and fixed....awesome.
    http://www.lumagen.com/docs/radiance20XX_020114.zip
    Production 020114- Fixed an issue when switching between 4k and 2k output modes where output style was not correctly used (2041/2042 only). Fixed an audio loss issue when changing between DTS-HD multi channel and DTS-HD 2 channel. Update time ~3 minutes @57k
  7. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 020314 Firmware Update
    Release Notes
    Fix for an occasional frame stutter for 4K video output (so only applies if using 4K output of 2041/2042).
    Eliminated test pattern blink for window patterns used by calibration software to allow for somewhat speedier calibrations. (Update time ~3 minutes @57k)
    Download Link
  8. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New *BETA* 021814 Firmware Update
    Release Notes
    NEW Image Based Auto Aspect
    We've expanded on the current input auto-aspect feature (in menu under "Input: HDMI Setup: Auto Aspect") to automate aspect selections based on the image as well as HDMI information.
    So, for example, if you play a 2.40 BluRay the Radiance20XX can automatically select a 2.40 input aspect for you thus eliminating the top & bottom bars without you lifting a finger.
    The new image detection will pick up letterbox and pillarbox formats so no more need to select the source aspect on the remote.
    Works great now but more to be added. Give it a try and let us know how it works for you and what improvements to this feature you'd like to see.
    This feature will only be available on the Radiance20XX and not older Radiance models due to hardware constraints.
    NEW 2.40 Input Aspect
    You can select a source aspect ratio of 2.40 now with 2 button presses on the remote, Alt- 2.35.
    Soft Edge
    Rounds the outside edges of the video off which gives movies a bit more of a theater look and can hide some issues at edges of displays.
    This setting now available in the menu under "Output: Styles: Soft Edge".
    (Update time ~15 minutes @57k)
    Download Link
  9. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 030114 Firmware Update
    Release Notes
    Fix for an issue with Cambridge audio receiver in front of Radiance resulting in severely green/pink colors if using Radiance default video EDID.
    Fix for bad onscreen test patterns within the grayscale command.
    Fix for issue when output 1 video was turned off causing occasional stutter on output 2 video.
    Fix for 2022/2042 copying analog input settings from one input memory to another.
    Fix for 2022/2042 analog inputs did not correctly select the output CMS and Styles.
    Note that the new image based auto aspect feature is still in beta.
    Update time ~15 minutes @57k from previous firmware.
    Download Link
    Lumagen Radiance XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D New 030114 Firmware Update
    Release Notes
    Fix for an issue with some DVI input displays in establishing a connection for video when display is powered up more than a minute after Radiance.
    Update time ~3 minutes @57k from previous firmware.
    Download Link
  10. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 050114 Firmware Update
    Release Notes
    Bugfix for some sources not showing video when switching to them.
    Fix for missing colorspace change from Integra.
    Fix for not getting lock on PCM output over coax output with Yamaha AVR. (Update time ~3 minutes @57k)
    Download Link
  11. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 050314 Firmware Update
    Release Notes
    Bugfix for certain combination of setting and sources that can give an occasional momentary screen tear in video.
    Added an option in menu under Input: HDMI Setup: Aspect Setup called Aspect Set which enables setting the same input aspect across src resolutions for the current memory for remote/rs232 input aspect commands. This is intended for control systems that know the source aspect but may set the aspect before the source changes modes.
    Download Link
  12. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2022, 2042) New 050914 Firmware Update
    Release Notes
    Bugfix for composite inputs (2022,2042 only) not working in 050114-050814 firmware. (Update time ~3 minutes @57k)
    Download Link
  13. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 050814 Firmware Update
    Release Notes
    Bugfix for couple issues with using configuration files from other units.
    Adds fan speed control options under "Other" on menu.
    Adds S-Video selection type for inputs 9 and 10 on 2124/2144 (Svideo uses component Green input for Y and component Blue input for C).
    Output trigger option now available if purchased using this firmware.
    Download Link
  14. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 060414 Firmware Update
    Release Notes
    Precision improvements were made for color accuracy including test patterns. (Update time ~15 minutes @57k)
    Download Link
  15. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 061014 Firmware Update
    Release Notes
    Fixes up a few bugs in some of the test patterns in the previous release. (Update time ~3 minutes @57k)
    Download Link
  16. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 070114 Firmware Update
    Release Notes
    A couple of APL test pattern fixups.
    Speeds up test patterns. (Update time ~3 minutes @57k)
    Download Link
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070114 Firmware Update
    Release Notes
    Adds capability (for 2041/2042) to Auto output selection to select 4K output modes when appropriate based on the displays 4K EDID information---works with 4K Sony projectors.
    Fix for sometimes incorrectly disabling a video output when changing between sources. (Update time ~3 minutes @57k)
    Download Link
  17. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070214 Firmware Update
    Release Notes
    Bugfix for issue that can blank output video to an output when switching memories in some cases. (Update time ~3 minutes @57k)
    Download Link
    Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070214 Firmware Update
    Release Notes
    Adds [email protected], [email protected], [email protected] output modes (2143/2144 only).
    Adds capability (for 2143/2144) to Auto output selection to select 4K output modes when appropriate based on the displays 4K EDID information---works with 4K Sony projectors.
    Slight improvement to 4k scaling.
    Fixup for 2144 analog video input 9 not working after factory reset.
    Bugfix for issue that can blank output video to an output when switching memories in some cases. (Update time ~15 minutes @57k)
    Download Link
  18. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 070314 Firmware Update
    Release Notes
    Fix for issue with rs232 test pattern usage that would often give a corrupted picture. (Update time ~3 minutes @57k)
    Download Link
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070314 Firmware Update
    Release Notes
    Download Link
  19. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070414 Firmware Update
    Release Notes
    Another rs232 test pattern problem fixed.
    An issue with screen being blank fixed.
    Problem with using left arrow on remote for aspect changes fixed. (Update time ~3 minutes @57k)
    Download Link
  20. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070514 Firmware Update
    Release Notes
    One more fix for an issue with rs232 test pattern usage via calibration software. (Update time ~3 minutes @57k)
    Download Link
  21. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070714 Firmware Update
    Release Notes
    Found 2 other issues with rs232 test pattern usage via calibration software.
    Fixed timing issue causing video corruption on output1 on some units. (Update time ~3 minutes @57k)
    Download Link
  22. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070814 Firmware Update
    Release Notes
    A fix for exiting test patterns when using vertical shift (bottom of screen left uncleared). (Update time ~3 minutes @57k)
    Download Link
  23. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 072014 Firmware Update
    Release Notes
    Small horizontal and vertical chroma improvements.
    Added a CUE (chroma upsample error) setting under Input: Video Setup: RES: Picture.
    Fixed an issue to handle 720p50 framepacked 3D source.
    Fixed an issue that sometimes caused problems updating at 57k baud (so after this update is made subsequent updates should run smoothly at 57k). Preferable to perform this update at 28k to avoid problems. (Update time ~15 minutes @57k)
    Download Link
  24. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 072114 Firmware Update
    Release Notes
    Fixed an issue that sometimes caused problems updating at 57k baud (so after this update is made subsequent updates should run smoothly at 57k). Preferable to perform this update at 28k to avoid problems. (note: bug occurred in 072014 and this update replaces it) (Update time ~15 minutes @57k)
    Download Link
  25. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 072214 Firmware Update
    Release Notes
    A bugfix for CUE filtering from 072114 firmware when upscaling.
    Improved the CUE filter menu, filter did not immediately turn on when enabled.) (Update time ~15 minutes @57k)
    Download Link
  26. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081614 Firmware Update
    Release Notes
    Added option to enable Darbee enhancement for just 2d or just 3d sources. (Update time ~15 minutes @57k)
    Download Link
  27. franin1
    franin1
    Mar 26, 2008
    537
    2
    Australia
    +74
  28. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081714 Firmware Update
    Release Notes
    The audio configuration menu had lost the spdif/coax selectable options from 050114-081614 in 20xx models only. (Update time ~3 minutes @57k)
    Download Link
  29. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081814 Firmware Update
    Release Notes
    Location values displayed for 9x9x9 gamut adjustment via the menu were off by 1 for a couple locations due to a rounding error. (Update time ~3 minutes @57k)
    Download Link
  30. ConnecTEDDD
    ConnecTEDDD
    Jun 13, 2011
    472
    Athens, Greece
    +93
    Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 091114 Firmware Update
    Release Notes
    Fix for a bug which under rare circumstances could give strange colors in grayscale that a user may have remedied by turning off and back on. (Update time ~15 minutes @57k)
    Download Link
