Lumagen -> Plasma Connection
Discussion in 'Plasma TVs Forum' started by rscott4563, Jan 11, 2004.
  1. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    I was wondering what would be the best connection to go for between my Lumagen Vision to my plasma (when I pick it) the Lumagen only has a VGA HD15 output and the manual states that the best siganl to use is RGBHV and not Component as then the Luma signal is spread across RG&B (does anyone know if this is true, any Lumagen users out there who've compared?), so the options would be VGA straight to the VGA input of the plasma, VGA -> 5BNC (if the plasma has a RGBHV BNC input), or VGA -> 5RCA (once again if the plasma can accept a RGBHV via RCA inputs)? Or if I did choose to go with component then it would be VGA -> VGA or VGA -> 3 RCA/BNC?
    Whats best?
    If it matters the plasma in question will be either a Panny6/Pio4/Fuji30 50"
    Ryan
  2. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    No one out there own or had experience of a Lumagen Vision and plasma??
    Anyone??
  3. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    Hi Ryan
    I've just ordered a Panny 6 and Lumagen Vision and will be using this cable to feed a Component (YPrPb) signal to the Plasma which has a 3 BNC Component Input.
    I was reading elsewhere that some plasmas only accept certain resolutions on RGBHV compared to YPrPb and that some also locked to a 4:3 ratio as they assumed it was a PC signal.
    Hope this helps.:)
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    I agree with Jim at Lumagen that RGBHV is preferable.
    Current plasma's don;t seem to suffer from the "aspect lock" syndrome.
    Gordon
  5. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    So Gordon would you say that I'd be better going for a VGA to VGA and using RGBHV or would I get any benifit using a VGA to 5RCA's or 5BNC's if the plasma accepts them??
    Also have you had chance to post the serial cable out?
    Ryan :smashin:
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    Ryan,
    Got in late Tuesday night. Not able to much yesterday and out till afternoon today. Hope to have cable in post this afternoon
    Gordon
  7. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Ryan
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    In theory the BNC should be best but I have never gone as far as doing PC input v's BNC terminal boards
    Gordon
  9. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Jase can I ask how much it cost in GBP for that cable including delivery and import duty etc... It looks just what I'll need, whether I'll be using RGBHV or YPrPb, I'll only need a 1m length.
    Ryan :smashin:
