Lumagen HDp +X-box
Discussion in 'Projectors, Screens & Video Processors' started by gwc, Feb 2, 2005.
  1. gwc
    gwc
    Oct 21, 2003
    497
    Wokingham, Berkshire
    +7
    I have come accross a problem with my Lumagen and X-box. When I load up some of the games the display get messed up (technical term :laugh: ). It looks like the odd & even field have been swapped which gives a jagged effects to lines. It only happens on some games, Fable, Star Wars Battelfronts other games are fine like ISS2, Jedi Academy.
    Has any one come across this problem?
    gwc
  2. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Is your XBox standard UK, USA, or chipped? How is it connected to your Lumagen?
  3. gwc
    gwc
    Oct 21, 2003
    497
    +7
    The X-box is a standard un-modded UK box. I am connecting to the Lumagen via a component input (Number 4).
    gwc
  4. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Well as it's unmodded I'm fairly cerrtain that all the games are output at the same resolution, so not sure what's happening. Have you tried the Lumagen Beta forum?
  5. gwc
    gwc
    Oct 21, 2003
    497
    +7
    I tried the Lumagen Beta forum, did'nt get any replies.
    gwc
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,051
    The Borders
    +2,522
    gwc
    Your the only Beta Tester with enough time for an X-Box :)
    I'll give the powers that be a nudge - its not something I've come across before.
    If you go direct to the Projector does it always 'report' the same signal with these various games.
    Best regards
    Joe
  7. Gordon @ Convergent AV
    Jul 13, 2000
    13,981
    +2,785
    Good grief....I was in Wokingham today......Jeez....should have been paying attention and I cold have popped in to check. Sorry but I have no answers for you.....My XBOX is R1 unit. If someone wants to lend me a game that does this effect I'll look at it.....my box is chipped so Ii might be able to recreate it and pass on info to Lumagen for de-bugging or an answer of some sort
    Gordon
  8. gwc
    gwc
    Oct 21, 2003
    497
    +7
    Joe,
    I checked the type of signal, for the various games, this morning. The games that work report 625 Line (Interlace) the games that don't report 525 Lines (Interlace). The games and the X-box were all bought in the UK.
    By the way Joe, the BetterCables 10 Metre DVI to HDMI worked out a treat. I get the odd drop out but that's to be expected with such a long DVI cable
    Gordon,
    That's a pity, as I e-mailed you December last year about performing the ISF calibration when the cinema room was complete (in late January/Early February). The room is now complete except for the Sky box. Hopeful you will be back in the area soon, so you could fit me in.
    Gary
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,051
    The Borders
    +2,522
    Hello Gary
    So the UK games that aren't working are outputting 480i(60) with a PAL colour space.
    We'll need to get on to Lumagen to see if that can be supported.
    Best regards
    Joe
  10. gwc
    gwc
    Oct 21, 2003
    497
    +7
    Hi Joe,
    Looks that way, seems strange that developers would select different line resolutions you think it would be standard.
    Gary
