Lumagen HDP Sync problem
Discussion in 'Projectors, Screens & Video Processors' started by gwc, Oct 9, 2004.
  1. gwc
    gwc
    Oct 21, 2003
    499
    Wokingham, Berkshire
    +7
    I have just bought a Vision HDP and I am trying to set the input to RGB with sync on green. When I look at the input type there is no RBsB only RGBS. Can anyone tell me how to change to sync on green?
    gwc
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    There is no RGBsync on green option. What is the source?
    I'll speak to Jim and Pat and see whether we can put RGsB support in (or if it is actually possible already)
    RGBCOMPOSITE SYNC is RGBS if you want to try that just now.
    Gordon
  3. gwc
    gwc
    Oct 21, 2003
    499
    +7
    Hi Gordon,
    The source I am using is a test pattern generator borrowed from work, it has an RGB output with sync on green.
    It states on Page 7 of the manual that RGsB is one of the input types.
    It is no big deal as I was just interested in looking a reference test pattern.
    Gary
    PS
    I am interested in getting the ISF Video Calibration done. Do you come down to the south much?
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Have you tried setting the HDP to RGBS to see if it looks at G as well as composite for a sync?
    I am down south often. In fact I was down yoru way last week. Next trip end of month. Email me for more info
    [email protected]
    Gordon
  5. gwc
    gwc
    Oct 21, 2003
    499
    +7
    Yes I tried the the RGBS setting and just got a blank screen, so it doesn't seem to look at G for the sysnc. I have connected up a DVD using the RGBS connections as per the manual and it is fine.
    I will e-mail you for more info for the calibration. Is there any info you need from me (regarding equipment etc)
    Gary
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,903
    The Borders
    +3,123
    Hello Gary
    Our man in Canada (Gordon) has asked me to confirm RGsB is possible using the RGBS setting - though you may well require a small in-line external filter on the sync line.
    The filters are built to order by Gordon and he'll sort one out for you as soon as he returns from his latest trip - Canada's quite a long way just to calibrate someone's Display I thought!!!
    Best regards
    Joe
  7. gwc
    gwc
    Oct 21, 2003
    499
    +7
    Hi Joe
    Thanks for the reply.
    As I said to Gordon it is no big deal I was just trying out a test pattern generator from work. I will normally be using a DVI input and and a RGBS input.
    Has he really gone to calibrate someone display ;) ?
    Gary
