Lumagen HDP/sky HD/CRT/DVI and HDCP
Discussion in 'Projectors, Screens & Video Processors' started by cutes6, Dec 20, 2006.
  1. cutes6
    cutes6
    Jan 3, 2001
    801
    Near Leeds
    +27
    I am trying to work out how to connect my Sky HD to the DVI input on the Lumagen and then out to my CRT projector.
    I am running into the Lumagen not passing through the signal because my projector is not HDCP compliant I assume.
    I have had a look around the net and have seen various options to overcome this problem but I don't know if these box's are still available in the UK - can anyone help with a solution.
    I am happy with HD through Component but I have run out of Component inputs to the lumagen and it made sense to try and use the DVI connections.
  2. Rob100
    Rob100
    Nov 3, 2002
    3,485
    +227
    I have a Vision FC4 on the DVI output of my HDQ to allow me to use HDMI in from my HD-A1 and get analogue out (1280x720 @ 47.952Hz).
    I found the output (using RGBHV) from the FC4 to be brighter than the analogue outs on the HDQ or DVI direct to my PJ so a little recal was needed.
    HTH,
    Rob.
  3. Timbo21
    Timbo21
    Dec 23, 2004
    4,686
    4
    London
    +340
  4. cutes6
    cutes6
    Jan 3, 2001
    801
    Near Leeds
    +27
    Thank you for your replies, I will talk to AV sales to establish the HDCP issue with these boxes, thanks once again
