Could anyone answer a couple of EDID questions with the Lumagen please.
a) I assume that even with pass through set config->dvi->edid = pass, that there will be no audio advertised even if the device that is being copied has audio capability in the EDID ?
For example, I am using a CLUX-14S 1:4 HDI splitter on the output of the Lumagen. This device simulated EDID is saying it has audio, but the Lumagen input says it does not support audio. This makes sense, but just want to check since I am splitting the output from a blu ray player into the amplifier (Onkyo 875) and the Lumagen. When the amp alone is connected I get full audio 7.1, master HD, true HD etc, when I add the Lumagen I get PCM.
I understand that the blu ray player will find the lowest common denominator and hence the PCM. I can use a splitter with EDID simulation instead and that should isolate the Lumagen from the Blu ray, but I just wondered if I was missing something and could avoid shelling out for another splitter.
b) Looking at the EDID from the Lumagen, Is there a "hangover" from earlier EDID settings when you use pass through?
For example,
1) I set user setting with YCbCr 444 and 422 set to no.
2) Switched to pass on the Lumagen.
The Lumagen input gave an EDID with these set as not supported.
3) Switched back to user and set YCbCr 444 and 422 set to yes.
4) Switched to pass.
The Lumagen input gave an EDID with these set as supported. It looks as if the pass through EDID was still being overriden by the previous user setting.
Any answer very much appreciated and sorry for the long post.
Cheers,
DJ
For example,
Cheers,
DJ
