Lumagen 21XX Range announced
Gordon @ Convergent AV
AVForums Sponsor
Well this was sprung on me a week ago. I've just received the official press release and it is below. Dealers in UK and EU should be getting pricing and info about them this morning once i've had my coffee. The only thing to add to the press release is that while the units currently will have all the features of the present range, plus the additional features mentioned in the press release, they will also be given a full 17x17x17 LUT capability, probably by end of May, early June once they 4K processing pipeline has been optimised. They have much faster and larger FPGA along with more memory compared to current 20xx units so do not expect 20xx units to get those features, though they may get other shared features but i am not at liberty to comment on those possible features at this time.
FOR IMMEDIATE RELEASE The Lumagen® Radiance™ Video Processor Family Adds New Members
April 16th, 2014 — Lumagen®, Inc., a specialist in the design and manufacture of products for the home and corporate theater markets, today announced four new members of its Radiance™ video processor family. These are the Radiance 2123™, the Radiance 2124™, the Radiance 2143™ and the Radiance 2144™.
Jim Peterson, Lumagen’s president, stated, “our customers were asking for more HDMI inputs, and the ability to scale source material up to 4k60. All four of these new products increase the HDMI input count to eight, and two can scale SD and HD source material up to 4k60. This maximizes video performance by taking advantage of Lumagen’s proprietary NoRing™ scaling to scale film source to 4k24 and video to 4k60. Supporting all the features of the Radiance 20XX series, including Darbee DVP™ processing, the new Radiance 21XX series answers our customer’s challenge.”
The Radiance 2123 and 2124 support input and output rates of up to 1080p60. The 2143 and 2144 increase the output rate to up to 4k60 in 8-bit 4:2:0 format.
The Radiance 2123, and Radiance 2143, support eight HDMI inputs, two HDMI outputs, a wired-IR command input, an RS232 command input, plus an internal USB-to-serial adapter. They are housed in a 1U rack mountable case.
The Radiance 2124, and Radiance 2144, add two component inputs, two composite inputs with 3D comb filter, two analog stereo inputs, one optical audio input, and three COAX audio inputs, plus a COAX audio output.
With its extensive processing, setup, and calibration, feature-set the Radiance family is perfectly suited for refining and enhancing the images presented by front projectors, and top-level flat-panel displays. With the introduction of these new products, the Radiance family continues as the video backbone for the best home theaters and media rooms.
The Radiance 2123 and 2143 are available immediately, and the Radiance 2124 and Radiance 2144 will be available in May.
Wookii
This is great news Gordon, I thought only having 4 HDMI inputs was a bit of an oversight in the 20XX range. The addition of 17 x 17 x 17 LUT capabilities is a little mind blowing - that's 4,913 data points - I wonder how long that will take to run with Calman AutoCal?!
Also, is this a typo Gordon:
. . . should it not be 4K/24fps?
So the difference between the 2143 and 2144 will just be the addition of legacy audio and video inputs, as per the 2043 vs 2044, both will have all the same video processing features and capabilities?
Also are these units HDMI 2.0 and HDCP 2.2 compliant?
AVForums Sponsor
No it's not a typo...the 212x products are 1080P output scalers and the 214x units are the 4K output scalers
The units that end in a 4 are the ones with the legacy audio and video inputs, yes. These also come in the 2U High XE case not the 1U high XS/20XX case as they can't fit it all in the small case I think.
These do not take in 4K so there is absolutely no requirement for HDCP2.2
As they support one of the HDMI2.0 options with their 4:2:0 4K 24/25/30/50/60Hz output they can be called HDMI2.0 output devices. There are not HDMI2.0 with HDCP2.2 chips for them to utilise in a product just now. Sometime after summer they should show the Radiance Pro hi-end super scaler which will have that capability..but that depends on silicon image actually supplying the hdmi2.0 chipset in the timeframe they have given...
Yes, 17x17x17 is pretty mental..and yes, it'll take a while to measure all that. It'll be worth it in the end though!
Wookii
Thanks Gordon, sorry I hadn't realised that they couldn't take a 4k input. I guess I'll be waiting for the Radiance Pro then when they arrive . . .
ConnecTEDDD
Radiance 21XX Series Video Processors
Radiance processing power, 17x17x17* (4913 point) CMS, Darbee DVP and optional [email protected]* output
*available soon via downloadable update, currently 9x9x9 and 4k24
For more details look here.
ConnecTEDDD
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 041514 Firmware Update
Release Notes
Bugfix for HDMI inputs 5-8 sometimes not showing video.
Download Link
ConnecTEDDD
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 041714 Firmware Update
Release Notes
Fix for issue of acquiring input video incorrectly. Menu correction for incorrectly displaying SPDIF options for 2123/2143.
Download Link
ConnecTEDDD
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 041814 Firmware Update
Release Notes
Bugfix for output setup menus not allowing certain input modes for inputs 5-8.
Download Link
ConnecTEDDD
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 041914 Firmware Update
Release Notes
A couple more input signal acquisition fixes.
See the utilities page now for a new configuration updater that works with the 21XX series.
Download Link
baronm
Had my first Lumagen (a 2123) supplied, installed and calibrated on Sunday by Gordon, and WOW, what a difference it has made! The contrast and colour are on another level compared to previously, and I had thought they were pretty good to start with! (I'd had the projector calibrated previously using ChromaPure).
I think the combination of the unit itself and the LightSpace kit that Gordon uses for the calibration is a definite winning combo (plus, of course, Gordon's winning personality and stories!). Roll on the 17x17x17 LUT firmware to make it even better!
ConnecTEDDD
Very nice, Gordon is a very experienced calibrator with LightSpace :)
I have designed a Cube Resolution Comparison Guide here to visualise the difference of calibrated color points precision over various cube resolution sizes between 5/9/17-Point Cube etc...
baronm
The illustrative difference from 5 -> 9 is pretty big, but the 9 -> 17 is immense!
Let's hope that we see a positive difference in real world user experiences.
ConnecTEDDD
There a lot of more control points in 17-Point vs. the 9-Point Cube, your skintones will be improved also, generally your image will have increased depth, more lifelike images, as you see at the image below the average Caucasian skin tone resides well away from any grey scale, or primary colour point.
LightSpace CMS Software were used for 17-Point Cube profilings to post-production/film industry since 2009, it's installed to major facilities around the world, here at consumer HT world we didn't knew anything for 3D-LUT until 2012 where Lumagen added the 5-Point Cube (free thou firmware update) capability to Lumagen Mini-3D.
In post-production/movie granding world, the 9-Point Cube is the minimum accepted cube resolution size for critical color-accurate profiling while 17-Point Cube is the post-production industry's 'defacto' cube resolution size for critical color-accurate profiling of any display.
ConnecTEDDD
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 050114 Firmware Update
Release Notes
Added support for 2124/2144 analog video and audio (not important for 2123/2143 units).
Bugfix for occasional small dashes in menu.
Bugfix for some sources not showing video when switching to them.
Update time ~15 minutes @57k from previous firmware.
Download Link
ConnecTEDDD
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 051014 Firmware Update
Release Notes
Corrects configuration CMS update problem in 050814.
Update time ~3 minutes @57k from previous firmware.
Download Link
ConnecTEDDD
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 051114 Firmware Update
Release Notes
Small fix to allow the rs232 command for the "Alt" key to work with delimiters on.
Another small fix to the config updating code.
Download Link
ConnecTEDDD
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 052314 Firmware Update
Release Notes
Adds "Off" to the fan control settings for 2123, 2143 for use in well vented areas demanding quietest operation.
Couple of bugfixes for problem getting a picture on some sources when going to standby and turning back on.
Another configuration compatibility correction.
Download Link
ConnecTEDDD
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 061414 Firmware Update
Release Notes
Precision improvements were made for color accuracy including test patterns. (Update time ~15 minutes @57k)
Download Link
ConnecTEDDD
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 061014 Firmware Update
Release Notes
Fixes up a few bugs in some of the test patterns in the previous release. (Update time ~3 minutes @57k)
Download Link
baronm
Any idea when we're likely to see an update for the 17x17x17 LUT for the 2123?
Latest News
Google set to launch the Pixel 7 and Pixel 7 Pro smartphones
  • By Ian Collen
  • Published
Focal launches Bathys noise-cancelling wireless headphones
  • By Ian Collen
  • Published
Formovie Theater UST projector hits the UK
  • By Ian Collen
  • Published
Sonus faber unveils new flagship Arena speaker series
  • By Ian Collen
  • Published
Sharp showcases its upcoming 4K TV and audio line-up
  • By Ian Collen
  • Published
