LT32DS6 - Question Regarding AV Channel
Discussion in 'LCD & LED LCD TVs Forum' started by Chorlton, Sep 6, 2005.
Tags:
  1. Chorlton
    Chorlton
    May 9, 2005
    63
    Finally getting there with the setup on my LT32.
    Only one little issue to resolve.
    I have tuned in analogue and digital tv, I have NTL on Ext1, my video recorder on Ext2 and dvd player on Ext4.
    The problem is when flicking from tv to cable or the dvd player, I press the AV button which takes me to an 'AV' channel which is nothing but static and white noise, I press the button again or use the program up/down buttons to then flick to Ext 1,2 etc...
    The manual is pitiful, in very small print it alludes that you can remove this 'AV' channel, but I cant find out how.
    Anyone know how to resolve this?
  2. Andy3
    Andy3
    Jun 20, 2005
    634
    Cheshire
    +19
    Hi Chorlton - We have the 26" version, and it does the same. I suppose it's included a an AV channel on the analogue tuner for video recorders, but if you don't use it (our video is on ch9 to mimic our previous TV setup) it is annoying. You can stop the noise & static by turning on the 'blue back' in the menu, but I didn't know the channel could be removed. You're right, the manual is p!ss-poor.
  3. Chorlton
    Chorlton
    May 9, 2005
    63
    Ive got blue back turned on, but you still get the initial static when you press the button.
    I think the only solution is to tune the video in as you have, or to copy an analogue channel onto the AV channel.
  4. Yak
    Yak
    Nov 12, 2004
    93
    +3
    If the LCDs work in a similar way to the CRTs then you can remove the 'extra' channel. Go into the menu where you manually tune in the analogue channels. At the top of the list there should be a channel marked 'av'. Select this and delete it. Now, when you press the AV button it should go straight to EXT-1
    Hope this helps
    Yak
  5. Glenagoolie
    Glenagoolie
    Jul 21, 2005
    164
    +5
    Did that work Chorlton ?, it didn't for me
  6. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    On the remote, there should be a button with an "I" on it, just press this then scroll to the input you want and click ok and it will jump straight to the input and you wont get this problem. Also you wont have to cycle through all other sources to get to the one you want, saving you time. :cool:
