LR and Centre too close? So don't bother?
Discussion in 'Home Cinema Buying & Building' started by Zarch, Jul 13, 2015.
  1. Zarch
    Zarch
    Jan 23, 2003
    3,577
    Sheffield
    +833
    I have an aging Sony all-in-one DAV-SC5 5.1 AV kit with 4 ohm speakers. It has no hdmi and i've got switching boxes and optical cables all over the place, so I think its time to upgrade.
    Feature wise I quite like the look of the Sony STRDN1050 receiver especially as it's on sale at Richer Sounds.
    From reading around, my old 4ohm speaker kit is going to need replacing too.
    But at the front, my L, centre and R are all just sat in a row on the TV cabinet, so barely a metre width between the L and R with the centre in the middle. No wider than my 42" plasma.
    There is nothing I can do about this, there is no room to put them any wider. The shelf the front speakers sit on isn't very tall either, so I could only fit satellite type speakers on there anyway.
    With so little separation, would I be better with a soundbar or something at the front? Like a combined L/centre/R speaker? Maybe even with a built in bit of sub oomph? Dare I say it a soundbar or soundbase type thing?
    Then some small satellite speakers for the rear effects? Could and would this work with the new Sony receiver?
    Or do I just get £99 Pioneer PIONEER S-HS100 5 piece speaker package from Richer Sounds and have done with it?
    Any thoughts or advice would be welcome.
    Thanks, Mick
  2. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    You can buy passive soundbars for your application. Something like the Monitor Audio Radius One or Wharfedale LCR. Then buy 2 rear speakers to match and a sub.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,913
    The Borders
    +3,568
    A pic of the current layout would help.
    I'm not convinced your 'upgrade' is going to deliver much of a change from your current system.
    Joe
