LP12 Lingo repair
Discussion in 'Hi-Fi Stereo Systems & Separates' started by quadfan, Nov 2, 2004.
  1. quadfan
    quadfan
    As the title suggests, mine is sick. There is a ticking noise (10-20 Hz?) when running - it sounds mechanical but isn't, unless it's the motor itself. I have been told this may be a fault on the Lingo, where one of the sine waves it generates drops out. Is this likely and how can I test it before spending £140 fixed price at Linn? Oh, just to rub salt in, I'm in France and they aren't easy to get serviced here.
  2. alexs2
    alexs2
    Nov 13, 2002
    13,959
    +1,671
    Have you tried either emailing or ringing Linn's customer service...their technical support has always been very helpful to me,and may give you some idea of what the likely problem is.
    Other than that,the only way of solving it would seem to be a visit to the dealer,unless you have a friendly electrician,who can test it's output for you.
