LP > Laptop.
Discussion in 'Computer Components' started by martin99, Jun 12, 2009.
  1. martin99
    martin99
    Sep 23, 2004
    283
    Surrey
    +14
    I want to rip LP's to a laptop at the best possible quality. What do I need.
    I guess an external sound box, but what one? ( I have the record deck!)
    cheers
    Martin
  2. bounce
    bounce
    Jan 21, 2005
    117
    Edinburgh
    +30
    The Terratech iVinyl is very good and comes with Sound Rescue software for cleaning up the tracks. It is a phono pre-amp with USB 2.0 output. It has options for MM/MC cartridges and a ground wire post etc.
  3. Jamestuk
    Jamestuk
    Nov 5, 2007
    411
    Ingolstadt, De
    +23
    If you didn't want to buy anything though you could simply plug that would normally go to the amp on your turntable into the line in on your soundcard, then record it with Audacity. Might need some babysitting (stopping recording, naming tracks etc) but could be worth a shot.
  4. martin99
    martin99
    Sep 23, 2004
    283
    Surrey
    +14
    Nice idea but i have a separate room for the Hi-Fi. So the I have to use a laptop.
    cheers
    Martin
