LOWEST PRICED DECENT 42" PLASMA ?
Discussion in 'Plasma TVs Forum' started by bustarhymes37, Nov 11, 2004.
  1. bustarhymes37
    bustarhymes37
    Nov 11, 2004
    33
    Hi Guys...what Is The Lowest Priced Decent 42" Plasma.i Watch A Lot Of Sport And The Occasional Movie.so Has Anybody Got Any Decent Suggestions For Me....cheers
  2. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    i dont know about lowest prices ,but if you can get a cheap pannasonic you wont go wrong.
    i personally have a viera,100 % happy
  3. Tony8377
    Tony8377
    Aug 19, 2004
    954
    Essex
    +4
    The advice you are going to get off this forum is buy the Panasonic PW6 @ around £1580. If you can't afford to buy this (+ input boards) I would just buy a larger CRT as the picture wont be as good on a cheaper plamsa. Sport/Football can be a problem on any plasma partly due to poor signal transmission. Only way to see if it's acceptable to you is to try and see a plasma working although seeing one setup properly can be a problem.
  4. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Pw6 can be picked up from av-sales for around £1600.
  5. bustarhymes37
    bustarhymes37
    Nov 11, 2004
    33
    thanks guys...much appreciated
