Lowe Concept Problems
Discussion in 'LCD & LED LCD TVs Forum' started by martin_d, Mar 15, 2006.
Tags:
  1. martin_d
    martin_d
    Feb 10, 2006
    104
    Had my concept L26 for about 3 weeks now and thedigital tuner is playing up:rolleyes:
  2. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    Uh huh! And?
    Seriously, all messing aside, speak with the retailer or Linnsight directly about measures you could try to see if it is indeed faulty or something else prior to the TV that's the problem.
    Even check the UM hints/advice section on solving some possible issues before jumping on the phone.
    Hope you get it resolved quickly, whatever is causing the problem.
  3. martin_d
    martin_d
    Feb 10, 2006
    104
    Got an engineer coming out Monday to have a look. While watching digi TV the opic breaks up, but when I connect through my old digi box it is fine, so retailer and Lowew suspect a problem with the TV. I've just no luck I think, but customer serive from TV and Video direct has been great
  4. LMKT
    LMKT
    well, you are lucky in the sense that someone is coming to sort it out for you. I have one or two dead pixels on the screen and spoke to Linnsight over a month ago about it and they said they will come out eventually just don't know when and will contact me to arrange near the time. I'm not happy with the customer service at all.
  5. martin_d
    martin_d
    Feb 10, 2006
    104
    Well Linnsight came out and I could not be happier with their service. Upgraded the software, so I can now get EPG and the picture problems seem to be resolved.
    I Also used a DVE disk to calibrate my TV and the pic is outstanding now!
  6. peahead
    peahead
    Dec 14, 2002
    3,130
    St.helens
    +447
    Glad to hear you got it sorted mate
