Hi JamieI've had a quick look and I believe neither the deck or the amp actually has a phono preamp built in, which would certainly explain low level sound.
It's hard to be 100% sure as it's not that easy to find info on older kit.
Something like this could be a good option if you do need a phono pre amp.
Pro-Ject Phono Box MM
Shop for Project Phono Box MM Phono Pre Amp with Richer Sounds for expert advice and lowest prices guaranteedwww.richersounds.com
It looks like the Ariston 910 is a rebadged Cambridge A1. IIRC the Cambridge was able to be ordered with or without a phono board which accounts for the Aux/Phono connector on the back. I suspect that you have a version without the phono board making that connection an AUX line level input. If you look inside then the phono board sit at the right hand side when looking from the front, if there is no cicuit board on that side of the cae the you have an AUX version and as suggested need an external Phono stage/preamp which can be had for £20 (Behringer PP400) upwards.
Youtube clip showing the inside of your amp, notice the space on the RHS with connector pins for the optional phono board.
