P
Phil38
I have got my home cinema connected up but the centre speaker is considerably quieter than the others. The only way to change the volume of this speaker is to select either large or small speaker in the set up menu.
Is there any way I can increase this speakers volume without changing it or is a swap the best option. I have done it all on a budget and am trying to keep the costs down.
Thanx for any help you can offer.
Cheers. Phil.
Cheers. Phil.
