Adamthekiwi
- Joined
- Jan 28, 2010
- Messages
- 33
- Reaction score
- 1
- Points
- 43
Hi all,
Looking for some advice on speaker selection - essentially, I'm lookiong for the best compromise between my desire for great sound for movies and hi-fi and my wife's desire for a system that does not intrude, visually, on the room.
So, I'm looking for a 5 speaker setup (plus active sub) where the centre and stereo channels are as slim-line as possible and the satellites are as small as they (reasonably) can be. The TV (a Panasonic TX-P42GT30) will be mounted on the wall, on an articulated bracket, near the corner of the room. The budget has some flexibility, but is likely to be hundreds (and, preferably, not a huge herd of them!), rather than thousands.
The absolute ideal would be something that fixes to the TV itself (as it will be able to move around in space, a bit), although I don't know if it's possible to get decent sound from such a system.
Thanks in advance for all suggestions!
Adam...
Adam...
