Low sub frequencies.
Discussion in 'Subwoofers' started by JIT, Jun 25, 2002.
  1. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    My current sub is rated at a low of 45Hz and so would buying the Paradigm PS1000 at 27Hz make a big improvement to my bottom end sound.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    It depends on how the manufacturers publish their statistics and without the + or - Db figure the 45 Hz is meaningless.
    In any event 45Hz is hardly deep bass as my satellites go down to 50Hz.
    In short, the answer is yes, the Paradigm will be a significant improvement.
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,771
    7
    2
    167
    Birmingham, UK
    +10,676
    Something that only goes down to forty something Hertz isn't a subwoofer in my opinion.
    Ideally you should try and get a sub which goes flattish down to 20Hz since this is what the Dolby and DTS specs say.
  4. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    Or you could buy a BagEnd Infrasub-18 or 12, which has extention down to 8 Hz... :) In some movies, bass below 20 Hz is present...
    But, like Spectre says, go for a sub which has bass down to 20 Hz flat in room. This does not mean it has to be flat in a anechoic situation. Room gain will extend bass down to 20 Hz in most cases, even if the specs mention 27 dB -3 dB.
