Low speaker stands - are there any?
witters
I need some low level speaker stands for a pair of Quad 11L speakers.
Approx 6 inches high with a tilt to angle the speakers upwards would be ideal.
Any ideas please?
harv
witters
Knightshade said:
Depending on whether or not you like real wood I got a custom made set of these for my Revel M22's. Also some tall versions for surround speakers.
Nice - dare I ask how much please?
Knightshade
The Revel stands were £300 at 520mm high. I did opt for the Ash and Wenge option which added a fair bit to the cost but they do fit the speaker bases exactly and it means I can bolt the speakers to the stands, something I couldn't do with anything other than the revel stand which doesn't look great. The taller surround stands (750mm) were £390.
