Low noise PSU with fan?
Discussion in 'Computer Components' started by mbede, Aug 17, 2005.
  1. mbede
    mbede
    May 18, 2004
    41
    Which PSU would you recommend? Fanless is out of my budget. I need at least 300w, with fan, as quiet as possible!
  2. SeanT
    SeanT
    Jan 28, 2005
    6,126
    Coventry
    +371
    akasa paxpower 400, fantastic bit of kit, about 45 quid if you shop around a bit
  3. shezzy2k
    shezzy2k
    Aug 17, 2004
    492
    28
    +26
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    The nexus ones are good and reliable I also have a silenx which was even quieter than the nexus with a radeon VE based machine but with a radeon 9800 pro produces a lot of coil whine. The nexus has no such problems and is only a tiny bit louder ( still not as loud as the dvd drive or hard drives.
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I got a 300W Antec Truepower from Ebuyer a month ago which is very quiet indeed and has plenty of other good features too. Only about £25. :)
  6. HSC
    HSC
    Nov 23, 2004
    1,911
    63
    Coventry
    +142
  7. 9761
    9761
    May 16, 2005
    499
    Hiper 350W PSU Ive got absolutly silent and cost £18
    I have one in my HTPC silent even with my ear to it. Even has the fan on for about 1 to 2 minutes after system shut down to keep it cool
  8. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    silenX make ones which are inaudible, they cost about £95 for a 400w one.
  9. jon stallard
    jon stallard
    I've built about 4 or 5 PC's in the last few months plus overhauled a few others and in each case (pun not intended) I've installed Hiper PSU's, mainly the 350watt jobbie. Quiet and cheap (soared up to £19.99 at my local now though:)). I've had one in one of my own PC's for near on a year now and now probs whatsoever. Why spend more?
    Jon.
  10. mjn
    mjn
    May 24, 2001
    18,392
    Herts, England
    +5,477
    Because high end systems need a lot of amps, and a £19.99 PSU just won't cut it......
  11. The Dude
    The Dude
    May 21, 2004
    5,213
    Beverley, East Yorkshire
    +1,521
  12. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,523
    A dystopian Grimsby
    +101
    I've got a SilenX PSU and I can't fault it on the noise front. The only downsides are the price and its tendency to get quite hot.
    In the past I've used PSU's from Q-technology (not to be confused with Q-tec whose products are quite shoddy) which have also been quiet and reliable.
    And if you do choose SilenX remember not to buy Ahanix SilenX (long story but both companies use the same SilenX brand, but Ahanix SilenX products are generally inferior although cheaper).
