Etienne A
Established Member
I'm looking for the resident experts opinions on this matter: on certain subs (my BK for example) it's possible to input both low & high levels at the same time - the BK even has separate controls for low and hi for fine tuning the setup.
Certain manufacturers recommend it - others don't make mention of it!
Other than differences in the roll off rate (24db vs 12db per octave) I can't think of any other reason why it would sound different (better or worse) .... maybe (as REL say on their site) the timbre of the amp is carried over to the sub - but isn't that a moot point, since it's low freq. (so timbre won't matter much) and it's gonna go thru' another amp circuit anyway (and mix with a new timbre signature).
I know I should just test it out .... and I intend to, but wiring is a tad complex on my setup so it's gonna have to wait. In the meanwhile I listened to a friend's setup using a couple of MA R90s and a BK Gemini2 sub ... and I have to say that HI sounded "fuller" - not night and day ... but definitely there was something extra. I can only attribute it to a difference in roll-off rate!
Opinions - discuss ...
