Low level hiss with Yam620 and missions?
Discussion in 'AV Receivers & Amplifiers' started by Markster, May 9, 2002.
  1. Markster
    Markster
    Im using the Yamaha DSPAX620 and Mission M series speakers.
    When using the dvd digital connection even with the dvd sound off i can turn the amp up as loud as possible and it is still quiet.
    If i choose any of the other inputs ie for watching sky etc, i get a hissing sound.
    Whilst watching sky the hissing is really starting to annoy me.
    I thought it was the phono cable between the skybox and the player so i changed these but it didnt change so i then removed this cable altogether and turned the volume up without anything plugged in and the hiss is still there.
    Does everyone else have this?
  2. mesak
    mesak
    Well, i am having the same thing with my Kenwood 7030 and Tannoys but only if turn-up the volume to -23 DB (usually it is VERY LOUD) - there's weird hiss appears and it doesn't happen with the digital connection (i use optical cable not coax).
    Daniel.
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,190
    +1,229
    probably the sky box . Probably not really built well enough for your average home cinema fan.
  4. Markster
    Markster
    It is not the sky box as it does the same connected to the tv and as above even when i unplug the sky box altogether i still get a hiss on that channel.
  5. WSC
    WSC
    Nov 1, 2001
    60
    I think that you will find that it is a "feature" of the Yamaha with analogue material. I originally had the Yamaha 420 and it was v. bad with hiss. When I got rid of that I auditioned the Yamaha 620, Denon 1802 and Marantz 5200 the Yamaha was not as bad as the 420 but it still wasn't good. Sorry but I suspect that if you can't take it back you will have to live with it.
