low height stand for TV
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by etaf, Sep 8, 2005.
  1. etaf
    etaf
    Dec 1, 2004
    1,013
    +63
    I just got back from IKEA looking for a TV stand
    had a read here BUT
    http://www.avforums.com/forums/showthread.php?t=223154
    I want a very low stand - the TV is in front of a window and I dont want it go over the window Glass - just below.
    At the moment its off to the side - but I think it might work better in the centre of window on a low stand
    TV is a 28" Toshiba {Its about 67CM wide 50CMHigh and 48CMdepth
    so the stand I'm after is like the OPPLI and certainly the price - to be on wheels - needs to hold a DVD Recorder, PVR freeview, Video which will probably go and maybe a 6.1 AMP - still thinking
    so measurements
    Depth 50CM is fine as the OPPLI
    width well that can vary but 150CM would be the max
    Height maybe 20CM to 25CM - which is the problem
    any suggestions
  2. bobbypunk
    bobbypunk
    Optimum @ www.optimum2000.com offer you the choice of pole sizes on their racks so you can use poles from 8cm to 60cm your choice.
    AV200 is 50cm deep, 110cm wide and height well the feet and glass add up to 10cm so you could give a shelf height of 8cm, 12cm or 15cm you choose, But the price is alot higher! @ £350.
