Low fog machines
Discussion in 'Shows & Events' started by viktor92, Jan 13, 2018.
Tags:
  1. viktor92
    viktor92
    Jan 12, 2018
    4
    Dubai
    Hello everyone,
    I am looking to buy a low fog machines for outdoor and indoor use for Halloween Event.
    For outdoor use the machine needs to cover around 70 m2 of surface. The surface is water.
    My idea is to put the machine close to the water and put the pipe under the water (to hide it), the end of the pipe to come above water level and from there to come the low fog. The length of the pipe should be around 6 meters. The pipe should go 50 cm depth and come again to the surface.
    As I don't have a lot experience with this type of machines I would like to ask is this possible, which brand and type of machines can be recommended for this type of use?
    After my research I found this machines:
    - Antari DNG-200
    - DJ Power X-SW1500
    For indoor use I want to cover area of around 150 m2. Which brand and type of machines you can recommend? If is possible I would like to use low fog machines which not required ice, to be safe to use and to don't trigger the fire alarm system?
    Also I need a machine which can give very low intensity but can works constantly for long period. I want to use to make effect like a fog is in witch's cauldron as you can see on the attached photo.
    Thanks for everyone in advance.
    Regards.
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,795
    7
    2
    167
    Birmingham, UK
    +10,712
    This is a forum ostensibly about home consumer electronics. I think you’re going to need to ask your question in a more specialised forum for outdoor, public, entertainment or arena events.
    I’d be very surprised if someone at AVForums will reply with a relevant answer to such an ‘off topic’ question.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,333
    The Borders
    +3,424
