Low end second system, which supports USB hard drive
DaveS00
Evening All,
I am looking to buy a second system, with a budget of up to £500/£600. I require:
play cd's
stream internet radio
external USB drive with music files (FLAC format), can plug into the system - external drive not included in budget.
speakers.
I would like a good sound from the system, but appreciate this area has compromises everywhere.
I was thinking of a bundle from Peter Tyson - a Yamaha all in one unit with Dali Spektor 2 speakers, but have read the Yamaha tends to go faulty in various ways just outside of 2 year warranty. The equivalent Demon unit doesn't support USB - Denon D-M41DAB
Ease of use is very important - hence was thinking an all-in-one, but not vital. The cd player will be used infrequently, streaming from the hard drive and internet radio will be the main usage.
All advice welcome
Dave
Paul7777x
A tough call for new stuff.
Here’s the best I can manage...
A streaming amp that’s better than it looks.
A CD player with usb stick capability.
And some exceptional speakers.
And it’s still more than your budget. 😔
However, these bad boys will bring it closer to your max outlay.
DaveS00
Thanks - I'll do some reading
DaveS00
A second hand laptop ,and a good DAC?.
I understand the laptop aspect, and ty for the suggestion - but that doesn't sit well with me - could be because my Win 10 machine took an M$ upgrade last week and went belly up. That aside surely a dedicated "hiFI" boxes are going to be less hassle than a laptop
TB Rich
The Denon N10 takes a USB, has CD, streaming (HEOS), and Airplay 2 + BT.
Bargain price here: £269.99
Leaves about £350 for a pair of speakers.
Tons of options out there, I've not heard anything in that price bracket but Dali Oberon 1 or KEF Q350, would be my first auditions I think.
But if you can do without a CD, an alternative could be a Yamaha WXC-50 (Amazon warehouse have a 'like new' for £259):
Amazon product
Paired with some active speakers, maybe Q Acoustics M20, £359 open box:
Paul7777x above is quite the active speakers advocate - he may have better suggestions than these.
That's £618 for the pairing above anyway.
You could always add one of those cheap Tibo or Tanget CD players for about £120 later on, and with a digital out into the WXC-50, should actually sound good too as you'd not be using the CD players likely poor DAC for that price.
DaveS00
Amazon product
I have been thinking about the Denon unit, and one i had many years ago did a very good job but I haven't found any reviews. I know the 10 is an outgoing model (but nothing wrong with that!). I was also considering the N11 in a bundle and stretching the budget a bit.
Ty very much for also finding the offers you mention in your reply - much appreciated
TB Rich
If it were me I wouldnt push the budget to go from an N10 to N11, the tier of products these things are at have a basically yearly refresh cycle give or take, and there is never anything more than the trivial to differentiate them. A new Bluetooth codec, or a new Airplay version etc, core hardware basically stays the same, in general.
I’d put any extra towards speakers, though I guess if you go too far up the speaker ladder then you run into an issue whereby potentially they exceed the all in one by too much! But I doubt that’s likely to rear itself in practical terms unless you go really exotic and expensive on them?!
