Low cost receiver recommendations for music & dvd ?
Discussion in 'AV Receivers & Amplifiers' started by Markster, Jul 16, 2001.
  1. Markster
    Markster
    Looking for a receiver for use with dvd movies and music cd's (therefore must be DD & DTS)
    Looking for as cheap as possible ie under £250 if possible.
    Any recommendations appreciated
    (speakers mission 702e)
    TIA
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Denon AVR 1801, costs about £399 at retail so you should be able to find it for less, around £300 should be possible.
  3. Guest
    ive just purchased the yamaha 520 rds receiver for £285 although u can get it cheaper if u shop around :)
    good quality amp, both dd and dts, fast decoding and very accurate stereo imo.
    70watts rms although it feels like much more in my small room. same 32bit lsi chip as the 620 main diff between the two being subtle differences on the front panel and the 520 has clip terminals for centre and rears whereas the 620 has binding posts all round, also the 620 is more powerfull at 90watts rms :)
    i highly rate the yamaha kit (as u can tell)
    and would deff recommend the 520 as an all round starter :)
  4. tan1415
    tan1415
    Lowbudget amps.
    Hmm have you checked out the Denon 1601?
    It's one of the best low budget amps around.
    An alternative is checking out the amps that has been replaced. Yamaha and Onkyo have just replaced there models. So i guess the Yamaha RXV596 and the Onkyo 575 will be much cheaper now. If you're lucky you can still find them.
    Kenwood and pioneer also have a good name with cheap HC amps.
  5. saggu1
    saggu1
    I would recommend the Yamaha DSP-620!!
    fantastic all round with all major specs..audio is brill too and with a
    5 star What-HiFi rating, u cant ask for much more!!
    :eek: :D :eek: :D :eek: :D :eek:
    may not be a receiver, however u still would be proud..
    [ 26-07-2001: Message edited by: Meluv DaPunani ]
  6. Koosnaff
    Koosnaff
    Jun 1, 2001
    79
    9
    Kent, UK
    I just got my Denon 1801 (definately a receiver) from www.stb-electronics.com.
    £250, absolutely sweet sound, and delivery was next morning for £24. I don't believe you'll find better sound quality for the money ...
  7. TJSMANGINA
    TJSMANGINA
    i have a sony strdb830 an im made up with it.you can get the strdb840 for 300 quid.100watts per channel an im well happy with mine :)
