Low contrast on DVD Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mr Cheese, Apr 16, 2003.
  1. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    412
    Down South
    +19
    Are there any DVD players that you can adjust the video level output (or contrast). My Wharfey 750s has no adjustment controls.
    I need more oommphh (technical term) on a tv that's already on max!
  2. gingerone
    gingerone
    Dec 10, 2002
    2,567
    +388
    I've just bought a jvc xv-n5 and it has more picture controls than you can shake a stick at, the picture and sound are also superb!
  3. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    412
    Down South
    +19
    Should have mentioned prefer to have multi-region and component out.
    Many thanks
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,216
    UK.
    +2,758
    The ambridge Audio range have that facility - only available at Richer Sounds though.
    I'm not sure, but I have the feeling the bare bones DVD interlaced output is the same for all 3 models (53, 55, 57), except 55 has pro-scan, and 57 has pro-scan and DVD-A.
    If that's the case, the 53 will do. The 57 has better picture quality than the Limit 9900SE, but not quite as good as the Toshiba 520 (or maybe 220 - not seen one yet).
    RS are good with returns, so you can try it and see if you like it.
    HTH
    Gary.
