low budget
Discussion in 'Plasma TVs Forum' started by danielthesaint, Oct 4, 2004.
  1. danielthesaint
    danielthesaint
    Sep 28, 2004
    47
    reading these posts is doing my head in so he goes...£1300 budget for a plasma screen. i know i am not going to get a bees knees screen but i only want it so i can watch a little tv plus to show off when people come round...has anybody got a budget plasma and been happy with it? :clap:
  2. Serpico
    Serpico
    Jun 22, 2002
    345
    Hull
    +7
    You'd be better off buying my 18 month old Philips 36 inch pixel plus tv for £500 and giving me room to buy a plasma.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    very very difficult this is a huge amount of money to be disapointed every time you switch on...... S/H possible to get a Panny PW5 or perhaps pio 433..... If you are prepared to put the work in then RS did have some 42 Fujitsu screens for £999 graded now thats the sort you want to buy some tweeks and other select kit will get mates who have spent £3k drooling
  4. danielthesaint
    danielthesaint
    Sep 28, 2004
    47
    i did find this screen
    Product Vision 42" Plasma Widescreen television Orion PM4230
    Description Main Specification
    Product Description
    Orion Electric PM4230 - plasma panel - PDP - 42"
    Product Type
    Plasma panel - colour
    Dimensions (WxDxH)
    107 cm x 8.1 cm x 66.9 cm
    Weight 29.5 kg Diagonal Size 42"
    Technology
    Plasma (PDP)
    Image Aspect Ratio
    16:9
    Sound Output Mode
    Stereo
    Remote control - infrared
    Power
    AC 110/230 V ( 50/60 Hz )
    Product Type
    Width 107 cm Depth 8.1 cm Height 66.9 cm
    Weight
    29.5 kg
    Television
    Technology
    Plasma (PDP)
    Diagonal Size
    42"
    Resolution
    853 x 480
    Image Aspect Ratio
    16:9
    Image Contrast Ratio
    3000:1
    Viewing Angle
    160 degrees
    Pixel Pitch
    1.08 mm
    Brightness
    550 cd/m2
    Features
    Screen saver
    Audio System
    Sound Output Mode
    Stereo
    External Speakers Amplifier Power (Total)
    20 Watt
    Connections
    Connector Type
    1 x VGA input
    1 x DVI-Digital
    1 x composite video input
    1 x S-Video input
    1 x component video input
    2 x speakers output
    Audio line-in
    Power
    Power Device
    Power supply - internal
    Voltage Required
    Power Consumption Operational
    320 Watt
    Price £1288.98 inc del.
  5. Serpico
    Serpico
    Jun 22, 2002
    345
    Hull
    +7
  6. jasonl
    jasonl
    Aug 11, 2004
    147
    +3
    maybe with a couple hundreds more, you can get the LG PX11 which i believe would be a lot better than that vision, but then again another couple hundreds more on top of that will get you in Panny teritory, but i guess that's stretching a bit too far
    try to get the LG at least
