k3vinjam3s
- Joined
- Aug 1, 2014
- Messages
- 12
- Reaction score
- 0
- Points
- 4
- Age
- 39
After a an extension build and full downstairs redecoration I'm after setting up a home cinema from scratch on a budget. I'm undecided between 2 av receivers which will be the bulk of my budget as I will hopefully add to this and upgrade the speakers later. I'm looking at the YAMAHA RXV375 and the Onkyo TX-NR525. Any advise regarding these or even alternatives around the same price would be great. I'm hoping to buy some budget floorstanding speakers as well at the same time then add a centre speaker and sub at a later date. I'm hoping that some floorstanders will provide adequate base for now till funds allow a sub. So any advice on those will be appreciated too.
I will be only be connecting sky hd box and pc for now and my phone for music from time to time. So although the needs I have are limited now I want some sort of futureproofing regarding the receiver.
Alternatively iv seen an all in one package which is the SONY BDVE4100
Smart 3D Home Cinema 5.1ch 1000W Bluetooth WiFi NFC. Although a good price I really want seperates if I can or would this provide what I need asap with the option of buying some bigger floorstanding speakers later on be a better option?
