Low and High Level Connection?
Discussion in 'Home Cinema Speakers' started by ELV, Sep 10, 2003.
  1. ELV
    ELV
    Jun 5, 2001
    650
    Up in the proper north
    +9
    Please could you tell me that if i connect a sub that allows both the high level and low level connectionsto be connected together, eg Mj Acoustics REF 100, with the neutronic cable, will i get the benefit of the high level connection when watching 5.1, or is it just of benefit when listening to stero.Your advice would be appreciated as it will have a bearing on which sub i go for in the 350-450 bracket.Any suggestions would be helpfull.
    Cheers.:confused: :confused: :confused:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    Not only is it not necessary to connect the speaker level connections to watch films but many subwoofers will not allow the simultaneous connection of both high and low connections.
    The MJ Acoustics 50 and 100 are both excellent subwoofers that have received five star ratings from What Hifi
