Love/Hate Relationship With A Servo 15
Discussion in 'Subwoofers' started by SBanga, Sep 16, 2005.
  1. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
    I love my Paradigm Servo 15! I bought it second hand and it has worked fine for approximately two months, except for some mains noise which I had solved with a mains conditioner. I really can't sing its praises highly enough as it is gut wrenchingly good.
    However, today I switched the sub on and I got nothing. There is no sound at all from it. I have tried different kettle leads and plugging it into another mains supply but it just does not work. Is there an internal fuse that may have fused that I can replace? If it isn't a user repairable problem, how would I go about getting it looked at? Would Richer Sounds be a good option, as it is local and they did sell them at one time?
    I have emailed Paradigm regarding the problem and am awaiting their reply. Just thought I'd ask here and get some advice. Thanks
  2. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    There is a internal fuse which some users have upgraded, do a search on the forums for details.
    Dave.
  3. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
