L
laxkyle17
Recently, i just bought two 6.5" Three-Way Triaxial Speakers from pyle and i made an enclosure for them. Power handling is 180 watts RMS and 360 Peak at 4 ohms. My problem is that i have an 186 watt home receiver that is rated at 8 ohms. I plan to wire the speakers in series, so that the ohm level matches up, but then will my watt mismatch be a problem? Or will an ohm mismatch be better?
Below is the proposed wiring...
